Voxel
Part of the Furniture
Continuation of:
https://www.snbforums.com/threads/custom-firmware-build-for-r9000.40125/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-41hf-1-0-2-41hf-hw.40481/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-42hf-1-0-2-42hf-hw.40688/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-43hf-1-0-2-43hf-hw.41167/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-44hf-1-0-2-44hf-hw.41301/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-45hf-1-0-2-45hf-hw.41820/
New version of my custom firmware build: 1.0.2.46HF/1.0.2.46HF-HW).
Changes (vs 1.0.2.45HF):
1. OpenSSL is upgraded 1.0.2l->1.0.2m. Fixes (OpenSSL changelog):
* bn_sqrx8x_internal carry bug on x86_64 (CVE-2017-3736).
* Malformed X.509 IPAddressFamily could cause OOB read (CVE-2017-3735).
2. Changes in OpenVPN client:
* Now Power LED is blinking if router fails to connect to OpenVPN server.
* "--cd $OPENVPN_CONF_DIR" option is added to startup script.
3. Bug in openvpn-easy-rsa package is fixed (cert files regeneration, OpenSSL 0.9.8->1.0.0).
4. e2fsprogs package is upgraded 1.43.6->1.43.7.
5. curl package is upgraded 7.55.1->7.56.1.
6. ethtool package is upgaded 4.11->4.13.
7. wget package is upgraded 1.19.1->1.19.2.
8. iperf package is upgraded 2.0.9a->2.0.10.
9. libubox package is upgraded 2017-09-29->2017-10-06.
10. ubus package is upgraded 2017-02-18->2017-11-06.
11. libxml package is upgraded 2.9.6->2.9.7.
12. sqlite package is upgraded 3200100->3210000.
13. expat package is upgraded 2.2.4->2.2.5.
14. dnscrypt-resolvers.csv is updated.
15. Host tools: three components are upgraded.
16. Toolchain: Patch is added to compiler (to support compilation by gcc 6.3.0).
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
No reset is needed to upgrade from my previous versions.
Difference 1.0.2.46HF-HW vs 1.0.2.46HF: “HW” version means hardware acceleration of OpenSSL.
P.S.
This version does not include the fix for the WPA2 Vulnerability in bridge mode (the last is not released by NETGEAR yet).
Voxel.
The link is:
P.S.
Voxel.
