Custom firmware build for R9000 v. 1.0.4.5HF/1.0.4.5HF-HW
Voxel
Part of the Furniture
Continuation of:
https://www.snbforums.com/threads/custom-firmware-build-for-r9000.40125/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-41hf-1-0-2-41hf-hw.40481/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-42hf-1-0-2-42hf-hw.40688/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-43hf-1-0-2-43hf-hw.41167/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-44hf-1-0-2-44hf-hw.41301/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-45hf-1-0-2-45hf-hw.41820/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-46hf-1-0-2-46hf-hw.42223/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-47hf-1-0-2-47hf-hw.42721/
hhttps://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-54hf-1-0-2-54hf-hw-1-0-3-7hf-1-0-3-7hf-hw.43854/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-3-8hf-1-0-3-8hf-hw.44204/
https://www.snbforums.com/threads/c...r9000-r8900-v-1-0-3-11hf-1-0-3-11hf-hw.45070/
https://www.snbforums.com/threads/c...r9000-r8900-v-1-0-3-12hf-1-0-3-12hf-hw.45843/
https://www.snbforums.com/threads/c...r-r9000-r8900-v-1-0-4-3hf-1-0-4-3hf-hw.46748/
New version of my custom firmware build: 1.0.4.5HF/1.0.4.5HF-HW.
Changes (vs 1.0.4.4HF/1.0.4.4HF-HW):
1. dnsmasq: dnsmasq.conf options are changed (compliance with v. 2.78).
2. OpenVPN client optimization.
3. ethtool package is upgaded 4.16->4.17.
4. iperf3 package is upgraded 3.5->3.6.
5. haveged package is upgraded 1.9.1->1.9.2.
6. transmission package is upgraded 2.93->2.94.
7. dbus package is upgraded 1.10.4->1.12.8.
8. curl package is upgraded 7.60.0->7.61.0.
9. libubox package is upgraded 2018-04-12->2018-06-07.
10. jansson package is upgraded 2.10->2.11.
11. libgcrypt package is upgraded 1.6.6->1.8.3.
12. libogg packages is upgraded 1.3.2->1.3.3.
13. HW version: mbedtls package is upgraded 2.7.0->2.11.0.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Difference 1.0.4.5HF-HW vs 1.0.4.5HF: “HW” version means hardware acceleration of OpenSSL.
Voxel.
Either version going to have better throughput without using VPN? I just got a R9000 today and installed your 1.0.4.5HF version and the router doesn't get the same speeds I was getting with my ASUS RT-AC86U with a 1g/1g fiber connection.
I figured this R9000 would have plenty of horsepower for gigabit internet.
I did not quite understand: do you use VPN client or no. It is better to flash 1.0.4.5HF-HW for OpenVPN.
Voxel.
Voxel.
I do not use vpn.
Also, would it be possible for you or someone to add some hardware usage info into the firmware? I hate how Netgear Genie doesn't tell you anything about CPU usage, RAM usage, internet speed, nothing! Why not?
