Custom firmware build for R9000 v. 1.0.4.6HF/1.0.4.6HF-HW
Voxel
Part of the Furniture
Continuation of:
https://www.snbforums.com/threads/custom-firmware-build-for-r9000.40125/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-41hf-1-0-2-41hf-hw.40481/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-42hf-1-0-2-42hf-hw.40688/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-43hf-1-0-2-43hf-hw.41167/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-44hf-1-0-2-44hf-hw.41301/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-45hf-1-0-2-45hf-hw.41820/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-46hf-1-0-2-46hf-hw.42223/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-47hf-1-0-2-47hf-hw.42721/
hhttps://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-54hf-1-0-2-54hf-hw-1-0-3-7hf-1-0-3-7hf-hw.43854/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-3-8hf-1-0-3-8hf-hw.44204/
https://www.snbforums.com/threads/c...r9000-r8900-v-1-0-3-11hf-1-0-3-11hf-hw.45070/
https://www.snbforums.com/threads/c...r9000-r8900-v-1-0-3-12hf-1-0-3-12hf-hw.45843/
https://www.snbforums.com/threads/c...r-r9000-r8900-v-1-0-4-3hf-1-0-4-3hf-hw.46748/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-4-5hf-1-0-4-5hf-hw.47893/
New version of my custom firmware build: 1.0.4.6HF/1.0.4.6HF-HW.
Changes (vs 1.0.4.5HF/1.0.4.5HF-HW):
1. uhttpd: Fix for Attached Device Names is included (similar to R7800).
2. OpenVPN client optimization.
3. OpenSSL is upgraded 1.0.2o->1.0.2p (CVE-2018-0732, CVE-2018-0737).
4. dnsmasq: dnsmasq.conf options optimized.
5. ntpclient: init script is changed (automatization of setting date for OpenVPN client).
6. avahi package is upgraded 0.6.32->0.7.
7. ubus package is upgraded 2018-01-16->2018-07-26.
8. libubox package is upgraded 2018-06-07->2018-07-25.
9. uci package is upgraded 2018-03-24->2018-08-11.
10. e2fsprogs package is upgraded 1.43.9->1.44.4.
11. util-linux package is upgraded 2.32->2.32.1.
12. ffmpeg package is upgraded 3.2.10->3.2.12.
13. libgpg-error package is upgraded 1.27->1.32
14. HW version: mbedtls package is upgraded 2.11.0->2.12.0.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Difference 1.0.4.6HF-HW vs 1.0.4.6HF: “HW” version means hardware acceleration of OpenSSL.
Voxel.
Just installed the HW version, it says under the Plex Media Server:
NTP time is not ready. Make sure that your NTP server is ok.
Never hard that message before, how to fix it?
But what is current time now in your R9000? Is it OK?
Voxel.
Nevermind, now the error message about the time is now fixed but now I get this:
Plex has some issues, please click Apply button to enable the Plex again.
If I hit Apply, then the message goes away then comes back after a few seconds
Hello Voxel :)
I saw that you added the option "11AD FW log collect", what is it?
Also do you know what the option add by netgear "Enable 11k" mean ?
Thank !
It happens sometime after flashing new firmware having old version of Plex already installed:
https://www.myopenrouter.com/comment/42124#comment-42124
you should remove it manually and enable again, see how:
https://www.myopenrouter.com/comment/42140#comment-42140
Voxel.
I just reset the router to factory settings and now the error message is gone.
This firmware is the best so far. Netgear are really disappointing at releasing firmware updates and your firmwares come to the rescue.
Info for Entware users: Entware is upgraded. It is enough to run:
/opt/bin/opkg update
/opt/bin/opkg upgrade
to upgrade your version.
Voxel.
