Custom script Error
tdashmike
Hello,
Could someone help me figure out what I'm doing wrong here? I'm trying to add extra configs to smb.conf to support Apple devices.
https://wiki.samba.org/index.php/Configure_Samba_to_Work_Better_with_Mac_OS_X
#!/bin/sh
CONFIG=$1
source /usr/sbin/helper.sh
pc_insert "[global]" "vfs objects = fruit streams_xattr" $CONFIG
pc_insert "[global]" "fruit:metadata = stream" $CONFIG
pc_insert "[global]" "fruit:model = MacSamba" $CONFIG
pc_insert "[global]" "fruit:posix_rename = yes" $CONFIG
pc_insert "[global]" "fruit:veto_appledouble = no" $CONFIG
pc_insert "[global]" "fruit:wipe_intentionally_left_blank_rfork = yes" $CONFIG
pc_insert "[global]" "fruit:delete_empty_adfiles = yes" $CONFIG
admin@AC68U:/jffs/scripts# ./smb.postconf
sed: -i requires an argument
Thank you!
- Mike
Even after you fix the script it won't make any difference because the router's version of Samba doesn't support vfs_fruit.
