Customize stubby.yml
lost_
I understand the privacy implication, but I'd like to send the subnet EDNS in the DoT queries. I'm using Quad9 9.9.9.11 (ECS enabled).
It seems that is controlled by this line in /etc/stubby/stubby.yml
edns_client_subnet_private: 1
How do I permanently either remove this line, or set it to 0?
Thanks Colin! Forgot about that directory.
For those who want to configure DoT the same way:
cat /jffs/scripts/stubby.postconf
#!/bin/sh
CONFIG=$1
source /usr/sbin/helper.sh
pc_replace "edns_client_subnet_private: 1" "edns_client_subnet_private: 0" $CONFIG
With this, my subnet is provided to Quad9 (which I'm fine with and they don't log). The resolved hosts are now the ones closest to me. I've tested with and without EDNS. Without EDNS, facebook resolved to the one in California (33 ms), and with it, it's the one in Virginia (10 ms). YMMV.
(In WAN page, set DNS over TLS to 9.9.9.11 and hostname dns11.quad9.net. In LAN, set DNSFilter to router or however you need it)
In /jffs/scripts create file stubby.postconf with contents:
#!/bin/sh
CONFIG=$1
Change properties of the file to 755
Here are changes I make:
#!/bin/sh
CONFIG=$1
pc_replace "round_robin_upstreams: 1" "round_robin_upstreams: 0" $CONFIG
pc_insert "tls_authentication: GETDNS_AUTHENTICATION_REQUIRED" "dnssec_return_status: GETDNS_EXTENSION_TRUE" $CONFIG
The last line enables DNSSEC validation to be done by Stubby. With this enabled disable DNSSEC in the router WAN settings.
