Daily reboot
Any software system that requires routine reboots is junk you should run away from as fast as possible. That's a clear indicator of incompetent programming.
Indeed. If there's a problem that necessitates a reboot then fix the problem, don't just hide it behind a reboot. Worse still, with scheduled reboots you may not even become aware of the problem until it bites you in the butt at the most inconvenient time. Best to be proactive rather than reactive.
