dansguardian virus filtering
sabot105mm
i just installed this program through entware but configuring it seems like its going to be a hassle since i have no knowledge in it. having looked at setup guides for redhat etc, i still dont know how to make it work on asuswrt. anybody have success in setting it up?
Hi, sabot105mm!
I've tested dansguardian with all it's heuristic filtering on my old RT-N16 and it's working. I've removed it because it was too heavy for RT-N16, but I think we may give him a chance on RT-N66U.
How stable is the RT n 66 using dansguardian?
What about performance / Speed issues using a 100Mbps Internet connnection?
Any experience using it on a router?
Hi, sabot105mm!
could you show me how to do it? when i try to execute it it says
/tmp/mnt/HD/Web1/Web$ dansguardian restart -f dansguardian.conf
Error reading custom image file: /opt/share/dansguardian/transparent1x1.gif
Unable to getpwnam() - does the proxy user exist?
Proxy user looking for is 'root'
We have no "root" user onboard. Please, replace it with "admin".
I have just insstalled dansguardian by bu doing an ipkg install dansguardian and am getting the same error. How do I change the user to admin so it will run?
Also does this packge include everything dansguardian need to run, do I need to install a proxy separately?
I have uncommented the user and group and user section in dansguardian.conf and changed root to nobody. I also created a dansguardian folder in /var/logs and did chown -R nobody:nobody dansguardian
Have a done this right so far?
ps i dont want to do virus filtering, i intend to edit the config files to do some basic webfiltering assuming i canget it to run.
Please please provide steps on how to just get it running for now, it is the n66u that I have.
I've managed to get privoxy and dansguardian running, just need to test dg actually filters.
Tried tinyproxy first but was too slow.
S *BUG* - DNS Director: Device Bypasses Filtering Asuswrt-Merlin 2
