spdMerlin Database Missing
blava_b
I'm having issues displaying charts in spdmon and when I accessed amtm to reset the database it appears that the database file is missing. I checked manually and it isn't there. How do I recreate it?
Choose an option: rt
WARNING: This will reset the spdMerlin database by deleting all database records.
A backup of the database will be created if you change your mind.
Do you want to continue? (y/n)
y
ls: /jffs/addons/spdmerlin.d/spdstats.db: No such file or directory
[: bad number
Sufficient free space to back up database, proceeding...
cp: can't stat '/jffs/addons/spdmerlin.d/spdstats.db': No such file or directory
Database backup failed, please check storage device
SQLite header and source version mismatch
2021-11-27 14:13:22 bd41822c7424d393a30e92ff6cb254d25c26769889c1499a18a0b9339f5d6c8a
2022-11-16 12:10:08 89c459e766ea7e9165d0beeb124708b955a4950d0f4792f457465d71b158d318
Failing USB drive?
Sorry for posting in an old thread. I was having trouble with vn-stat hanging when doing an Update from amtm, so I decided to uninstall vn-stat, presumably preserving the database files, then re-installing. Now all my historical data is gone. What is the location of those database files? Maybe my weekly backup catches that directory. But if not, what directory should I be backing up so I'm covered for the next time I need to reinstall vn-stat.
This does not seems to related to spdMerlin.
Anyway, for vnstat, you can look it up in this directory /opt/var/lib/vnstat
Changing the db file in that directory does not change the stats.
Yup, sorry, wrong topic.
