Daylight Saving - last Sunday
Carnbroe
In the UK daylight saving starts on the last sunday in March. The settings in the router appear to be by the number of the Sunday i.e.1st 2nd all the way up to 5th Sunday. How do you set this for the last Sunday? If you set it to change for the 5th Sunday and there are only 4 sundays that year does it not get changed ?
Any suggestions how to set it for the Last Sunday ?
5th acts as last.
Search the forum. Comes up every year!
Spent 15 mins searching and found nothing :(
Thanks for the reply
This should find some posts.... i.e. 6th post in the returned results list
