DDNS setup Tutorial
mikefrommanchester
Hi
Does anyone know of a Tutorial for Merlin Firmware (but I assume it's similiar to stock) for setting up DDNS properly and configuring the correct router settings?
Sorry if this is already obvious but I have searched.
Thanks in advance.
Thanks for your reply.
Since writing I've got it working with no-ip.
It was quite straightforward actually now I've done it.
One question; I don't seem to be able to login to the router locally anymore with my original username and password.
I have to use my no-ip URL.
Is that normal or I have misconfigured something?
Its pretty easy to setup.
I do not have this issue, I am able to get to my router by the local LAN IP and use the username and password I setup
Sorry but I'm still stuck with this and I don't know how to access the router using the local ip of 192.168.1.254 - I just get a blank page.
I can log in via https://router.asus.com:8443 and then it gives me a message
This server could not prove that it is router.asus.com; its security certificate is from (MY DDNS PC NAME).ddns.net. This may be caused by a misconfiguration or an attacker intercepting your connection.
I've obviously messed something up or is this expected behaviour with HTTPS?
It only seems to happen on first access via router.asus.com (because I added exception) - although the browser reports the page is not secure.
Can anyone point me in the right direction?
This is what I see from DDNS Settings:
This is what I see from Administration page:
What are you trying to do, that looks correct. Did you get a registered success message?
Well it all seems to work remotely using NO-IP, but when I access the router locally from my PC I get:
I can ignore the warning and login but is that normal and nothing to worry about?
It is https generating the message since you are using a private certificate. There is no point using https locally, so just change back to http
TURN OFF REMOTE ACCESS FROM THE WAN!
Ah that explains it. Thanks.
I thought remote access from WAN was necessary to allow DDNS but obviously it's not.
I've just realisded I can't now access my router from the DDNS address.
Are you sure this works with Remote Access from WAN turned off?
You do not want WAN access enabled! Sure way to get hacked. Use a VPN or Instant Guard to access the router from the internet.
