Debian and Entware apps not working - ASUS RT-AC68U
hytgonra
I am trying to set up a few services. Only 1 time got all things working and each, I do the same thing using tutorials.
Right now installed Optware apps only and its not laggy. I think there is some issue with file location after installation, but have no idea how to check it.
After each new implementation, I do restart of the router. Also installing apps on optware. Works so far
You either have Optware installed or Entware, you can't have both installed at the same time. You can't install Debian apps unless you have Debian installed on the router.
one more question - whats best to use for Optware/Debian packages? Regular HDD, SSD or Pendrive and why?
That would depend entirely on what packages you want to install and how you are using them. Obviously HDDs and SDDs are much faster and have greater capacities but that may not be necessary for your usage.
