So you are saying there is no way to know the range of a router unless you actually buy it and test it for yourself?
100% correct if it's a first go-around without having
any wifi gear on-site beforehand. If you have a pre-existing router or AP to compare against, then you can probably predict how well the new hardware would do in relation, but even so, the only true way to know with complete certainty is to survey with the new gear on-site.
Does business class AP's give wider range or more stable system? Does it feel any different browsing on your regular consumer router(ex ASUS) or a Ruckus AP?
That's a tough question to give a universal answer to. In general, though, when looking at a like-for-like swap, all other variables held equal, business-class APs actually
won't provide as much effective range per single piece of hardware, because they're often designed to operate at
lower amplification than your typical consumer all-in-one, whose sole purpose is to blast as much signal (and noise along with it) as possible. That being said, it's the
client device and it's weaker radio that is almost always the limiting factor on how much actual throughput and/or connection quality can be attained from that far away. And that's where the often-superior approach of
more, lower-power radios comes in -- precisely the paradigm for which most business APs are crafted. Granted, you have stuff like Asus AiMesh in the consumer space, but if distributed wifi is the point to begin with, I'd argue you'd be better off with the likes of even just an entry-level centralized business AP product (ie. TP-Link Omada) for generally better stability, native VLAN support, PoE support, better management, deeper feature set, etc.
Regarding reliability, though, yes, business-class APs will often be more stability-focused in their development, and so often will provide a more reliable experience for the clients. Various brand systems will offer these qualities to varying degrees, but overall, that's the trend when moving from consumer to business and then to enterprise-grade gear, in almost any product segment.
TL;DR on range - For a more complete understanding on how to get the best wifi performance for your needs, see this excellent
Duckware article for a solid primer on the subject.
I thought of installing business class AP's but at $700 per AP, no wireless mesh, and I heard you must have an expensive yearly subscription its just not worth it.I am not sure if the price difference=the added benefit difference. The closest thing I got to was wired Ubiquiti, not sure if overhyped consumer APs or on par with Ruckus and Aruba.
I'm not sure what wireless product line you were looking at, but the above is, at best, an over-estimation of per-unit price, mesh capability and licensing fees, for the majority of business products, even for a good amount enterprise products. I personally use Ruckus APs, whose best-bang-for-the-buck R510's are ~$250 each on Amazon (albeit gray market), come with rock-solid wired
and wireless multi-point mesh, a proper enterprise-class control plane, and run without a discrete controller, for free, with no yearly licensing fees at all, ever. And they're on the
higher end of the cost spectrum. You can achieve similar capability with Omada, UniFi, Granstream GWN, Aruba Instant On, the list goes on -- all for less (MSRP at least). Sure, if you want to pay through the nose, you would do so with Cisco Aironet, Juniper Mist, AeroHive with a cloud NG subscription, Aruba with an Aruba Central subscription, etc. but you certainly don't have to, just to get rock-solid, high-speed-everywhere wifi at home. Not even close.
