Default Wi-Fi Settings
Wycleff
Can someone please upload the default General and Professional Settings of 2,4 and 5 Wi-Fi as a screenshot here.
(The stock settings after a factory reset)
Thank You.
bbunge
Part of the Furniture
Thank You.
Which router?
OzarkEdge
Thank You.
Would need to know the router model and firmware version, yes... but I would not hold your breath waiting for someone to reset their router so you don't have to. :)
Can you save your configuration, reset to see the defaults, and then restore your configuration?
OE
Wycleff
OE
You're right, but i'm not forcing anyone to reset their router, and I know how time-consuming that is, but maybe I'll get lucky and someone will have a screen of the stock Wi-Fi settings floating around.
So, stay healthy, guy's.
Sumsurfguy
Thank You.
Here you go, defaults for ax58u running 386.3_2
General
Screenshot from 2021-11-20 11-44-05.pngScreenshot from 2021-11-20 11-44-47.png
Professional 2.4
Screenshot from 2021-11-20 11-45-41.pngScreenshot from 2021-11-20 11-46-05.png
