Hi
I often have a problem with devices getting the same IP from the DHCP.
In the network overview I see it says "static" even though it should be DHCP.
Is there a quick fix, when this happens ? Can I restart/clear the DHCP so the devices get new IP's ?
Should I lower the leasetime, which is 86400 ?
I have a couple of reserved IP's, those work fine, and is listed as "manual"
Devices getting the same IP's:
Samsung S8, Samsung Gear S3, 2 different ChromeCasts.
Normally it is fixed by itself after a day, but I want to fix it faster and hopefully eliminate it.
It is not very WAF friendly when the Chromecast is not working because of IP conflict.
Info:
AC68U - firmware 380.68_4
Wifi disabled. Ubiquiti AP Lite for wifi
Info:
