justanothercog
I'm running a fairly new AX-88U and moved configuration information over from a AC-88U about 2 months ago. Both are/were running the latest Merlin firmware (now 384.17_0 on the AX). The problem is that the list of manually assigned IP addresses says "No data in table". However, the list of shows many of the static address devices that were previously set. Other devices don't show at all anymore in the Network Map even though I can login to those devices, knowing the static IP address I had set before.
- How can I get the static list to populate on the DHCP page?
- How can I get all active network devices to show up on the "Clients" and "View list" in the Network Map?
If I try and set a new static IP for a device, it never takes, nor is it displayed.
