1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
DHCP Offer/Discover/Ack/Request
Discussion in 'Asuswrt-Merlin' started by EventPhotoMan, Jun 3, 2019.
  1. EventPhotoMan
    EventPhotoMan Senior Member
    Mar 29, 2018
    429
    Does anyone know how many times the router will offer an IP address after discovery?
    Is there a limit before the router gives up offering?
    The client does not seems to be receiving the offer, so no DHCPACK.
  2. ColinTaylor
    ColinTaylor Part of the Furniture
    Mar 31, 2014
    8,827
    UK
    Once.
  3. EventPhotoMan
    Mar 29, 2018
    429
    Discover, offer, and then repeat.
    Seems like the client is not listening.
    DHCPDISCOVER(br0) d0:73:d5:23:09:53
    Jun 3 22:21:43 dnsmasq-dhcp[777]: DHCPOFFER(br0) 192.168.1.86 d0:73:d5:23:09:53
    Jun 3 22:21:44 dnsmasq-dhcp[777]: DHCPDISCOVER(br0) d0:73:d5:23:09:53
    Jun 3 22:21:44 dnsmasq-dhcp[777]: DHCPOFFER(br0) 192.168.1.86 d0:73:d5:23:09:53
    Jun 3 22:21:46 dnsmasq-dhcp[777]: DHCPDISCOVER(br0) d0:73:d5:23:09:53
    Jun 3 22:21:46 dnsmasq-dhcp[777]: DHCPOFFER(br0) 192.168.1.86 d0:73:d5:23:09:53
    Jun 3 22:21:48 dnsmasq-dhcp[777]:
  4. EventPhotoMan
    Mar 29, 2018
    429
  5. EventPhotoMan
    Mar 29, 2018
    429
    AA75D252-2689-4A5D-99CC-FF230DA0F2A1.jpeg Colin, even funnier, 192.168.1.86 is not even an active client on the network...
  6. ColinTaylor
    Mar 31, 2014
    8,827
    UK
    I'm not sure I understand your point. Of course it won't show as an active client, there hasn't been a DHCPREQUEST/DHCPACK.
    EventPhotoMan likes this.
  7. EventPhotoMan
    Mar 29, 2018
    429
    Why then is there a DCHPDISCOVER/OFFER? With no device present?
  8. ColinTaylor
    Mar 31, 2014
    8,827
    UK
    :confused:
    Because the lease isn't created and the client's network interface isn't configured until the DHCPACK has been sent.
    EventPhotoMan and dave14305 like this.
  9. EventPhotoMan
    Mar 29, 2018
    429
    Yes I understand that. But why The discovery of a device? I guess I really need to find out what device it is and physically turn it on and see what happens
  10. OMNI619
    OMNI619 Regular Contributor
    Feb 3, 2018
    100
    I had similar issues I had to reset router to factory settings and unplug all my clients boot up the router first then power up clients
    Sent from my SAMSUNG-SM-G920AZ using Tapatalk
  11. ColinTaylor
    Mar 31, 2014
    8,827
    UK
    I really don't understand your confusion. The client is already turned on because it is the client that is issuing the DCHPDISCOVER.
    dave14305 likes this.
  12. dave14305
    dave14305 Very Senior Member
    May 19, 2018
    872
    It’s a LifX light bulb.
  13. EventPhotoMan
    Mar 29, 2018
    429
    Well I found the device that was causing the problem. The device was on and was trying to connect to my network, I’m not sure why the ball was not associating and acknowledging a lease
    Unfortunately there’s not enough information that comes back from the system log
  14. EventPhotoMan
    Mar 29, 2018
    429
    Thank you but yes I did know that, I have like 75 lightbulbs in my house
    The application doesn’t help either because it does not list all the Mac addresses, and where I have assigned them to
  15. WuTang LAN
    WuTang LAN Regular Contributor
    May 5, 2019
    69
    @EventPhotoMan
    There are some knowledgeable people on this board - @ColinTaylor is one of them.
    I'm not sure why you would ask for help, then discredit every answer that has (correctly) been given to you.
  16. WuTang LAN
    May 5, 2019
    69
    We know this from your system log.
    What information are you expecting? The information in your system log is standard.
  17. EventPhotoMan
    Mar 29, 2018
    429
    Just confirming I guess. I couldn’t find the physical device that was on, at first. Then confirmed it was on and trying to renew I lease.
    Why there was no DHCPACK, I do not know.
    Turning the device off/one did fix the problem, but it still saddles my why this occurred.
    Thanks.
