dhcp-option DNS in OpenVPN's custom configuration field
Intrepid2007
Hello forum members,
One of my OpenVPN connections is a Torguard VPN tunnel. The configuration comes without DNS servers so I have to specify my own DNS server.
So in the custom configuration field I added the following line:
dhcp-option DNS1.1.1.1
This works perfectly.
However I want like to specify a second DNS server so I just added a second line:
dhcp-option DNS 1.0.0.1
In the example above I use Cloudflare DNS servers but in reality I use alternative DNS servers for this particular OpenVPN connection.
Apparently it doesn't work that way, the client/server connection never connects....
Does the custom configuration field in OpenVPN allow to specify 2 DNS servers or is this not supported in OpenVPN at all?
Regards
eibgrad
Part of the Furniture
It says right in the OpenVPN documentation that you can set additional DNS options.
--dhcp-option type [parm] ...
DNS addr -- Set primary domain name server IPv4 or IPv6 address. Repeat this option to set secondary DNS server addresses.
I did notice you're missing a space between the word DNS and 1.1.1.1 in your post. I assume that's NOT the case in the actual custom config field.
As long as you don't create a typo for the DNS setting, I don't see how any of this could prevent the OpenVPN client from at least connecting. How the actual specified DNS server(s) are handled from that point is an entirely different issue.
Intrepid2007
The space in the example is indeed an error, in the actual router settings there is a space..
dhcp-option DNS 1.1.1.1
So it should be something like this?
