Dhcp range and fixed
itpp20
A simple yes or no :)
dhcp range .10 - .250
fixed ip's .20 and .100 - .120
When dhcp issues an IP address is it aware of these fixed devices ?
I would prefer to set dhcp range to .121 - .250 to avoid usage in the fixed range but I seem to remember I could not set a fixed ip outside the dhcp range.
ColinTaylor
Part of the Furniture
If you are referring to IP addresses that are reserved in the Manually Assigned IP around the DHCP list then yes the DHCP server is aware of those addresses and will not attempt to give them to other clients.
..but I seem to remember I could not set a fixed ip outside the dhcp range.
Not true, you can reserve IP addresses inside or outside of the DHCP range.
itpp20
Tnx. It must have been before merlin I had that reserve issue, can't test it till end of year, AP is too far away.
EventPhotoMan
I do the statis IP address all the time outside the DHCP server settings. and yes the resevered ones (where I set the client's GUI to a specific address) work fine also.
EventPhotoMan
I do a DCHP range of 192.168.1 69 to 192.168.1.136
the static address I use are 192.168.1.1 to 192.168.1.68 and 192.168.1.37 to 192.168.254, is skip IP address where some are reserved.
