DHCP Server settings..
rirusssma
First ... I´m new at setting Routers. I have a RT-N66U and Windows 7
I´d like to know what should I place in the LAN->DHCP Server menu boxes.
I have this example marked with Box 1-4 (Press Here)
Would the information in the boxes that I have be placed as it shows in RED in this next picture? (Press Here)
Thanks for any help.
Depending on your ISP's requirements, most of these may be filled in "automatically" when you make a connection, and some are likely to be blank.
Can you please describe how you connect to your ISP without a router, both the hardware that you have and the process that you use for connecting without a router?
More information from you is needed before your questions can be answered.
Thanks.
Thanks for the reply, RogerSC.
I have an antenna outside and then I can plug into a PoE box directly to the PC (or Router).
