Did Upgrade Reset Admin Password?
bryan_moore
I recently went from 3004.388.8_2 to 3004.388.8_4 on my Asus RT-AX86U router and my admin password, which I can verify is correct, no longer allows me to log in to the router. Two questions:
  1. Has anyone else seen this?
  2. Does anyone have a suggestion on how to get into the router?
Thanks for the help...
That upgrade shouldn't have effected the admin password.
There have been multiple reports of this happening recently but in those cases it was a side effect of the router having been infected with malware. That only became apparent when they did a factory reset to try and get access and found that their router no longer worked properly.
So be careful, and make sure that you have an old copy of the "Save settings" file in case the worst happens.
P.S. The malware in question appeared to attack routers that had AiCloud enabled.
Thanks for that... How would I have an old copy of save settings? I've never thought to back that up in the past.
The chances of this being malware is very low.
If you are sure the password you are using is correct and it is no longer working then your only/best option to push the reset button and setup your router from scratch.
If you have a saved settings file then you could reset, download and revert to 8_2, factory reset, install your backup file and then try to upgrade again.
Sounds stupid by try the ages old default passwords used on some routers:
admin
or
password
Check that you haven't inadvertently hit the caps lock key when entering in your password. Passwords are case sensitive.
Last resort, try a reset via the reset button on the back of the unit or a hard factory reset.
If the router was hit by the recent malware it appears the new stock Asuswrt update fixes it... at least sort of.
@bryan_moore, if you get no Wi-Fi after hard reset just flash latest stock Asuswrt and see if it restores the router. Then you can flash your preferred 3rd party firmware, reset again and reconfigure manually. This model was the most affected one.
Thanks, everyone, for all the suggestions.
I "solved" the issue by putting the router into "Recovery Mode" and eventually had success flashing the latest official firmware from Asus itself.
Both the latest asus-wrt & immediately previous release failed to flash via commands run from my Linux install and both also failed after downloading, installing, and running the official Asus recovery tool on my wife's Windows laptop. The only firmware that could be installed and get the router to run was the latest official Asus one.
Again, thanks to everyone here!
This firmware and for this particular model contains form of malware damages reversal. Good to know yours is working again. 👍
Does anyone have a sense of when the Merlin version will be cleaned up? I've discovered that the official Asus firmware does not allow NFS mounting and that's a necessity for me...
Yes you misunderstood. The previous post was suggesting that the latest firmware from both Asus and Merlin contains new code that attempts to repair damage caused by the recent malware.
