different DIR-655 models?
zaphyr
I'm looking to buy a new router, and the 655 seems to be the one for me.
Looking at different webshops, I see there are two different models of the 655? Some are named "D-Link Xtreme N Gigabit Router DIR-655" and others "D-Link DIR-655 Wireless N Gigabit Router" and at some shops the names are even mixed together in the same article.
Are these really two different routers, or are the webshops just confused...?
Thanks! :)
thiggins
Mr. Easy
Staff member
As long as the model # is the same, it's the same product. Note that there are different hardware versions, but all have the same ordering part #. A4 is the latest version.
Some may disagree, but the hardware version doesn't make a difference.
zaphyr
Thanks! I can see in the router charts that the A4 version is scoring higher, but it shouldn't make any difference to me, either one of the two 655's on that list will do perfectly :)
