Different Gateway using DHCP Reservation for specific device ?
aiwaxxx
Hi All
Is it possible to assign a different gateway using DHCP Reservation for specific device ?
My default DHCP Pool is 192.168.100.0/24 ; GW: 192.168.100.2
For a specific PC, I need to assign gateway 192.168.100.1, all others should have 192.168.100.2 as gateway. This device doesnt support Static IP (Google Nest Hub).
Address reservation on ASUS supports only MAC+IP combination, there is no option for gateway.
Using ASUS AC87U, Firmware Version:384.7_2
You should be able to do that by using a custom config file (dnsmasq.conf.add) that contains dhcp-host and dhcp-option commands for the device in question. 384.7_2 is quite old now so I can't remember how exactly it formats the dnsmasq config file.
