1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
different wireless mode for main/guest
Discussion in 'Asuswrt-Merlin' started by thobux, Feb 22, 2019.
  1. thobux
    thobux Occasional Visitor
    Sep 19, 2018
    34
    I was wondering if I can downgrade a guest network to Legacy while keeping N for main wifi.
    Why would I be interested in such a setup: I got LIFX bulbs that need legacy settings to not loose connectivity…
    Any ideas … thanks
  2. RMerlin
    RMerlin Super Moderator
    Apr 14, 2012
    29,276
    Canada
    No. Guests are just virtual interface, they share the same radio, therefore the same transport settings.
  3. FreshJR
    FreshJR Very Senior Member
    Oct 8, 2016
    1,164
    Not in my expierence.
    I had my 2.4g network set to N only for the longest time ( I have no old devices).
    I then later dug out an old laptop since I needed an SD card reader. I got confused since I couldn’t connect that laptop the main WiFi as I wanted transfer the data onto to my NAS but that laptop could connect the the guest network without issue.
    Long story short, the laptop has no wireless n functionality.
    Main network was 2.4n only
    Guest network did not take settings from the main network and was 2.4legacy.
    Laptop could still connect to guest.
    Has me wondering if the legacy switch only does not allow wireless b/g to connect to the network the software side but still broadcast the signal.
  4. thobux
    Sep 19, 2018
    34
    Hmm, interesting. I'll give it a try at some point.
  5. thobux
    Sep 19, 2018
    34
    So I did some tests here. My situation is with LIFX bulbs/beams. It seems your approach works for the beam (no legacy for 2.4 but connected via guest) but not for the bulb. Hmm, undecided.
