Direct client web traffic through VPN provider same router is connected to
YPNvexed
Hello
I have AC3100 with both OpenVPN router and client set up (that was fun). I can connect to my LAN (10.168.2.0/24) and I can access the web through the router as a OpenVPN server using my iphone. I am using the default subnet of 10.8.0.0 and connecting with TCP 443 port.
The final piece that is missing, is I want the client (i.e my iphone in this case) to surf the web using my VPN providers ip, rather than my ISP ip. I have tried using the push "route x.x.x.x x.x.x.x vpn_gateway" approach in the server config, but I either didn't get the right IP in there (not sure what the X's should be replaced with) or this is not the correct approach.
Has anyone done this when both a client and server are running on the same router?
Thank you for any help you can provide on this!
