davecrobinson
I've searched through but can't find if there is any way to disable the reset button on the router from the GUI? Router is AX58U.
Casually would only cause a reboot. It must be pressed and held for a factory reset.and it would stop it being pressed casually (if that is a thing)!
Are you thinking of electrifying the case, or just blowing it up?Connect it to the mains.
Just electrocuting those pressing the reset button, blowing it up would be a bit extreme.Are you thinking of electrifying the case, or just blowing it up?
Welcome To SNBForums
