Disk check results on RT-N66U
cdysthe
I have a 3TB NAS attached to my RT-N66U. It's formatted ext3 and works without any problems. I have set it to check the disk once every week and was expecting to see the results of the check in the scan result field, but it's always empty. Is there a way I get access to the weekly disk check results? It would also be interesting to know what kind of check it actually is. Is it the good 'ol Linux fsck.ext3?
iirc, merlin said something about the router not having enough memory for fsck and you'd probably need to pull the drive and attach it to a computer to run it, sorry.
So even if you set the router to check the drive once a week it won't do it? I could swear I did a manual test when I installed it and the disk was checked, but I may remember wrong. It's not that I need it checked, but I would like to have it checked now and then if possible.
