Diversion Diversion and Asuswrt
keef
Hello. I am using Diversion 4.1.12 and Asuswrt 386.2.6. I have one PC that does not have banner ads blocked (an example is speedtest.net). I am using both Edge and Firefox with no ad blocking apps installed on any pc (wired pc, others with ads blocked are both wired and wireless plus cell phone). I went over every setting on the router and found nothing related to that pc. I reset the router, re-installed diversion with the same result.
Does this make any sense? I cannot see what I have overlooked and its driving me nuts.
thanks guys
What is the output of "ipconfig /all" on the PC (assuming it's windows), are the DNS settings showing the router? Or some other DNS?
Ex. some VPN software will change the DNS settings to point to the VPN providers DNS servers.
Next, did you check if either of the browsers has DoH enabled? In FF those are under "Network Settings | Enable DNS over HTTPS", that box should not be checked. I don't use Edge so can't help with that.
You went over the router settings, but what about the computer's settings? Have you checked to see how the computer's configured (IP address, DNS servers, security software, VPN software, etc.)? Could be that computer (or the software on it) is configured to bypass the router/Diversion.
Here it the output trying two different adapters.
thanks
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : 802.11ac Wireless LAN Card
Physical Address. . . . . . . . . : A0-9D-C1-1E-D4-E7
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::2595:b7a7:63f8:a54f%26(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.98(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Friday, July 9, 2021 12:26:24 AM
Lease Expires . . . . . . . . . . : Saturday, July 10, 2021 12:26:21 AM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 446733761
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-28-3F-9E-88-A8-5E-45-53-83-A2
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 00-15-83-F7-20-83
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : A8-5E-45-53-83-A2
Link-local IPv6 Address . . . . . : fe80::8056:2c3a:cbf4:cef3%3(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.46(Preferred)
Lease Obtained. . . . . . . . . . : Thursday, July 8, 2021 10:00:45 AM
Lease Expires . . . . . . . . . . : Saturday, July 10, 2021 12:25:59 AM
DHCPv6 IAID . . . . . . . . . . . : 363355717
Good call. I totally overlooked the PC.
thanks
thanks
Nothing jumps out, all the DNS servers are listed as 1.1 which is your router. I'd disable one of the network cards and turn off IPv6 (unless you really need it) and test again
