Diversion Diversion blocks shopping suggestions
Shadowflake
Dear,
I have installed diversion on a new router.
The add blocking works. But it is also blocking the suggested shopping sites when i m searching for a item that i want to buy. For example if a want to buy a new Asus router it Will show up in Google but the link is blocked by diversion.
How do it solve this issue?
Regards
Dear,
Regards
Bah... I Will give the answer to my own question. Add googleadservices.com to the whitelist. Proces the whitelist and reboot the router.
I found that I needed to whitelist quite a few more to get all google ads to work with Diversion [kind of defeats the object of Diversion - but tell that to the wife ;)]
adservice.google.com
analytics.google.com
www.googleadservices.com
ssl.google-analytics.com
googleads.g.doubleclick.net
www.googletagmanager.com
