Diversion Diversion &/or Skynet blocking LG TV's access to LG servers?
  • ATTENTION! You'll notice a Prefix dropdown when you create a thread. If your post applies to one of the topics listed, please use that Prefix for your post. When browsing the thread list you can use the Prefix to filter the view.
brec
I have reason for suspicion but I haven't confirmed this issue, nor have I pinned it down to either Diversion or Skynet, but it would help me to do one or both if anyone has experienced the subject issue. A long shot, I know.
dave14305
Part of the Furniture
Both tools will log what they block if you have logging enabled.
brec
Logging is on in both, but I'm not sure what I'm looking for; I have no IP addresses of the target servers -- only certain functions not "loading" on the TV. I'm ignorantly guessing that what's blocked is outbound from the TV.
As an end run, if there's a way to exempt requests from or replies to a specified local IP address, I could manually assign the TV's address. Currently it's DHCP-assigned.
brec
Thanks for the clue! I can see how to whitelist WAN domains, but not how to whitelist a local device.
Edit: it's SkyNet, not Diversion.
brec
Whoops! Turns out it's SkyNet that's causing the issue. Now to see if I can whitelist a local device in SkyNet....
brec
And now I'm not sure it's either of them. Some kind of timing/caching is making it hard to isolate the problem.
Henceforth I'll try to avoid turning this thread into a blog :)
dave14305
Logs from both tools that show the TV local IP should narrow it down, especially if it’s Skynet.
brec
It's Diversion. Here are some contiguous log entries; the TV is 192.168.50.8; there is one "blocked" entry in the 7th line, where it's reported "is 192.168.50.2," which is the pixelserv-tls IP; I don't know what's going on with the blocked domain in the 8th-10th lines:
Oct 20 05:39:48 dnsmasq[12524]: query[A] us.lgrecommends.lgappstv.com from 192.168.50.8
Oct 20 05:39:48 dnsmasq[12524]: forwarded us.lgrecommends.lgappstv.com to 1.1.1.2
Oct 20 05:39:49 dnsmasq[12524]: reply us.lgrecommends.lgappstv.com is <CNAME>
Oct 20 05:39:49 dnsmasq[12524]: reply us-lgrecommends-lgappstv-com.aws-prd.net is 52.12.52.75
Oct 20 05:39:49 dnsmasq[12524]: reply us-lgrecommends-lgappstv-com.aws-prd.net is 44.238.228.41
Oct 20 05:39:50 dnsmasq[12524]: query[A] US.lgtvsdp.com from 192.168.50.8
Oct 20 05:39:50 dnsmasq[12524]: blocked by blockinglist US.lgtvsdp.com is 192.168.50.2
Oct 20 05:39:50 dnsmasq[12524]: query[AAAA] US.lgtvsdp.com from 192.168.50.8
Oct 20 05:39:50 dnsmasq[12524]: forwarded US.lgtvsdp.com to 1.1.1.2
Oct 20 05:39:50 dnsmasq[12524]: reply US.lgtvsdp.com is <CNAME>
Oct 20 05:39:51 dnsmasq[12524]: query[A] us.tvsdp.lgeapi.com from 192.168.50.8
Oct 20 05:39:51 dnsmasq[12524]: forwarded us.tvsdp.lgeapi.com to 1.1.1.2
Oct 20 05:39:51 dnsmasq[12524]: reply us.tvsdp.lgeapi.com is <CNAME>
Oct 20 05:39:51 dnsmasq[12524]: reply aicip.tvsdp.lgeapi.com is <CNAME>
Oct 20 05:39:51 dnsmasq[12524]: reply aicip-tvsdp-lgeapi-com.aws-prd.net is 35.164.252.43
Here are some later ones filtered on the TV's IP:
05:52:14 dnsmasq[12524]: query[A] us.lgrecommends.lgappstv.com from 192.168.50.8
05:52:15 dnsmasq[12524]: query[A] US.lgtvsdp.com from 192.168.50.8
05:52:15 dnsmasq[12524]: query[AAAA] US.lgtvsdp.com from 192.168.50.8
05:52:16 dnsmasq[12524]: query[A] us.tvsdp.lgeapi.com from 192.168.50.8
05:52:51 dnsmasq[12524]: query[A] discovery.meethue.com from 192.168.50.8
05:52:51 dnsmasq[12524]: query[AAAA] discovery.meethue.com from 192.168.50.8
Since the only domain actually reported blocked is US.lgtvsdp.com, I thought I'd whitelist it, but:
 Enter domain  [e=Exit] US.lgtvsdp.com
____________________________________________________
 US.lgtvsdp.com
 was not found in blocking list(s), looking for
 near match(es):
 none found in blocking list Standard
 none found in secondary blocking list
 US.lgtvsdp.com
 If you add it anyway, it may have no effect unless
 you select a larger blocking list.
 The domain will be marked #(forced-entry) and is
 not re-added to the blocking list if you remove it.
 Add it to whitelist anyway? [1=Yes 2=No]
dave14305
US.lgtvsdp.com
near match(es):
US.lgtvsdp.com
Try entering it in all lowercase.
dave14305
It’s making a query for the IPv6 address (type AAAA), which I assume isn’t enabled on your router.
brec
That worked to whitelist it, which worked to solve one of the TV issues. There's another, more minor, issue which I'll keep trying to isolate.
