jrichard326
On Hagezi's github the following was posted (https://github.com/hagezi/dns-blocklists/issues/4651)
"The DNS flood can be reduced somewhat if you have the option of configuring the cache TTL (time to live) for blocked domains in the DNS. I use a blocked TTL of 3600 sec. so that a new request to the DNS is only made after 1 hour if a domain is blocked, unless the client ignores the TTL.
Flooding the DNS is a typical tracker behaviour when the tracker is blocked. Some trackers then go wild and make requests every second."
Is it possible to adjust TTL in Diversion?
