1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
Diversion - the Router Adblocker
Discussion in 'Asuswrt-Merlin' started by thelonelycoder, Aug 25, 2018.
  1. thelonelycoder
    thelonelycoder Part of the Furniture
    Jan 23, 2014
    4,360
    Switzerland
    Welcome
    This is Diversion - the Router Adblocker for Asuswrt-Merlin
    AB-Solution is now Diversion
    All install and update info, as well as other useful information is on the Diversion website.
    September 14, 2018
    Small update, no version change. See here:
    https://www.snbforums.com/threads/diversion-the-router-adblocker.48538/page-20#post-430826
    September 9, 2018
    Diversion 4.0.1 is now available
    See this post or the website for the change log
    Diversion is free to use under the GNU General Public License version 3 (GPL-3.0).
    If you like Diversion and find it useful, you can help it's further development with a donation.
    Thank you!
    To see the fancy ticks and crosses that Diversion shows during operations, make sure your SSH terminal encoding is set to UTF-8.
    Diversion is interactive. To start the Diversion UI after installation, use
    diversion
    For quick operation options without starting the UI, use
    diversion help
    to make yourself familiar with the available options.
    Screenshots of Diversion 4.0, standard and extended menu (more options o)
    [​IMG]
    Zonkd, mad_daddy, sasax and 30 others like this.
  2. Please support SNBForums! Just click on this link before you buy something from Amazon and we'll get a small commission on anything you buy. Thanks!
  3. thelonelycoder
    Jan 23, 2014
    4,360
    Switzerland
    Reserved post
    HowIFix likes this.
  4. skeal
    skeal Very Senior Member
    Apr 30, 2016
    1,764
    Canada
    All I can say is thank you sir! You are awesome. Donations on the way!!!
  5. M@rco
    [email protected] Very Senior Member
    Dec 23, 2017
    533
    /tmp
    This is awesome, can't wait to try it. Thank for all your hard work @thelonelycoder!
  6. Jack Yaz
    Jack Yaz Very Senior Member
    Apr 20, 2017
    1,188
    Yay new software! Looking good so far - need to merge back some of my jffs scripts though (it did warn me :) )
    EDIT: example, it wiped the services-start file completely! All restored now, now to push some adblocking test goodness
    thelonelycoder likes this.
  7. thelonelycoder
    Jan 23, 2014
    4,360
    Switzerland
    It merges the commonly used scripts around here. Those that amtm supports.
    For all the funky other stuff that some people paste into the jffs/scripts directory I have no patience to merge when coming from AB-Solution 3.11.x.
    Diversion 4.0 can handle it though...
  8. Jack Yaz
    Apr 20, 2017
    1,188
    Makes sense. Installer backed it up to entware usb so all good, I run my own strict backups/changelogs too since I have to dabble :)
    If I need to make changes, does Diversion check for edits like AB-S and re-apply? i.e. anything I should specifically not do to cause conflicts?
    Thanks for the new release :)
    Vexira likes this.
  9. thelonelycoder
    Jan 23, 2014
    4,360
    Switzerland
    Diversion uses one-liners to hook itself into the start scripts, for example /jffs/scripts/post-mount:
    . /jffs/scripts/post-mount.div # Added by Diversion
    This sources the new /jffs/scripts/post-mount.div that starts Entware, no matter whether that device has a label or changes its name for some reason.
    If something goes haywire, just run d and Re-Install (does this from local files) or Update Diversion (fetches all new files from remote).
    Both ways fix it as all used files are locally stored on your router.
    The Diversion files are at /opt/share/diversion, while the dnsmasq log files are at /opt/var/log
  10. Jack Yaz
    Apr 20, 2017
    1,188
    Cheers!
  11. thelonelycoder
    Jan 23, 2014
    4,360
    Switzerland
    Sorry about the minimal Diversion website. For now this old-old AB-Solution website snapshot will have to do.
    You all have what you wanted. And I'm glad Diversion is out.
    Evictoria, skeal and Jack Yaz like this.
  12. thelonelycoder
    Jan 23, 2014
    4,360
    Switzerland
    I like the Merriam Webster No. 2 definition of diversion best:
    skeal likes this.
  13. Protik
    Protik Regular Contributor
    Oct 31, 2017
    184
    /boot
    Thanks @thelonelycoder for the update.
    Unfortunately, the update did not work for me. I have been using a test version of pixelserv-tls v2.1.3-test.4 for a while. It seems while upgrading 3.11.2, the Diversion installer fails to install pixelserv-tls. The error it shows is:
      i  Checking white and blacklists
      ✔  Whitelist
      ✔  Blacklist
      ✔  Wildcard blacklist created
      i  Probing for pixelserv-tls
      i  Installing pixelserv-tls
    Downloading http://bin.entware.net/armv7sf-k2.6/Packages.gz
    Updated list of available packages in /opt/var/opkg-lists/entware
    Collected errors:
     * opkg_download_pkg: Package pixelserv-tls is not available from any configured src.
     * opkg_install_pkg: Failed to download pixelserv-tls. Perhaps you need to run 'opkg update'?
     * opkg_install_cmd: Cannot install package pixelserv-tls.
    Installing pixelserv-tls (V35.HZ12.Kk-1) to root...
        ____  _                    _
       |  _ \(_)_   _____ _ __ ___(_) ___  _ __
       | | | | \ \ / / _ \ '__/ __| |/ _ \| '_ \
       | |_| | |\ V /  __/ |  \__ \ | (_) | | | |
       |____/|_| \_/ \___|_|  |___/_|\___/|_| |_|
     This is Diversion 4.0      coded by thelonelycoder
     Welcome to Diversion - the Router Adblocker!
     Diversion is not installed on this router...
    ____________________________________________________
     [ Error ] pixelserv-tls install failed.
     Install it now? [1=Yes e=Exit] 1
    I tried running the installer again, now it starts the process and does not recognize the earlier Ab-Solution. I guess because during the first attempt, all files were wiped out.
  14. jrmwvu04
    jrmwvu04 Senior Member
    Mar 29, 2016
    450
    United States
    Congrats @thelonelycoder - I don’t use it, but it is clear a lot of people do. And the screenshots are pretty which I do appreciate.
  15. thelonelycoder
    Jan 23, 2014
    4,360
    Switzerland
    There was no need to re-Install since you used a very recent version.
    Did you port or install new when given the option?
  16. Protik
    Oct 31, 2017
    184
    /boot
    I did port. The full stack trace:
    [email protected]:/tmp/home/root# /usr/sbin/curl -Os https://diversion.ch/install && sh install
        ____  _                    _
     [ i ] Getting latest installer file
     [ ✔ ] install.div         integrated
     [ i ] Checking router
     [ ✔ ] Asuswrt-Merlin
     [ ✔ ] dos2unix
     [ ✔ ] Netstat
     [ ✔ ] Compatible device(s)
     [ ✔ ] Internet
     [ i ] Router check complete
      !  AB-Solution 3.11.2 installation found
         at /tmp/mnt/pdas001/adblocking
     1. Port to Diversion 4.0 (highly recommended)
        Keep AB-Solution 3.11.2 settings
     2. Install Diversion 4.0
        Discard AB-Solution 3.11.2 settings
     Enter your selection [1=Port 2=New] 1
      i  Porting AB-Solution 3.11.2 to Diversion 4.0 Standard
      i  Probing for Entware
      ✔  Entware is already installed
      ✔  Diversion directory structure created
      i  Stopping AB-Solution 3.11.2
      ✔  Old cron jobs deleted
     Checking pixelserv-tls (AB-Solution)...              alive.
     Shutting down pixelserv-tls...              done.
      ✔  pixelserv-tls stopped
      ✔  Old start scripts cleaned
      i  AB-Solution 3.11.2 stopped
      i  Porting AB-Solution 3.11.2 files and settings
      ✔  White and blacklist ported
      ✔  Shared whitelist ported
      ✔  Blocking file ported
      ✔  Email settings ported
      ✔  Pixelserv switches file ported
      ✔  Client names backup file ported
      ✔  Stats file(s) ported
      ✔  shooter40sw hosts list ported
      ✔  Blocking list settings ported
      ✔  Ad-blocking stats ported
      ✔  Dnsmasq log files ported
      ✔  Communication settings ported
      i  Porting of AB-Solution 3.11.2 complete
      i  Installing Diversion 4.0 Standard
      i  Getting Diversion Standard files from
         https://diversion.ch/diversion/4.0
      ✔  backup.div          integrated
      ✔  functions.div       integrated
      ✔  install.div         integrated
      ✔  post-conf.div       integrated
      ✔  post-mount.div      integrated
      ✔  rc.func.div         integrated
      ✔  rotate-logs.div     integrated
      ✔  stats.div           integrated
      ✔  S80pixelserv-tls    integrated
      ✔  theme.div           integrated
      ✔  update.div          integrated
      ✔  update-bf.div       integrated
      ✔  update-notification integrated
      ✔  write-config.div    integrated
      ✔  Whitelist
      ✔  Blacklist
    Collected errors:
        ____  _                    _
  17. Protik
    Oct 31, 2017
    184
    /boot
    There has been a lot going on within pixelserv-tls. As per @kvic 's suggestion a few people have been doing a lot of tinkering to optimize the test versions. I guess it's best not to tinker with pixelser-tls if a test version is running.
  18. thelonelycoder
    Jan 23, 2014
    4,360
    Switzerland
    Whats your output of:
    opkg list-installed | grep pixelserv-tls
  19. Protik
    Oct 31, 2017
    184
    /boot
    I get nothing,
    [email protected]:/tmp/home/root# opkg list-installed | grep pixelserv-tls
  20. thelonelycoder
    Jan 23, 2014
    4,360
    Switzerland
    If you have the beta version installed through amtm or @kvic installer then it should have worked.
    I tested that extensively on my ARM and MIPS routers.
  21. thelonelycoder
    Jan 23, 2014
    4,360
    Switzerland
