Diversion Diversion Webui Tab - Link to pixelserv-tls-stats ... http not https ??
kernol
@thelonelycoder - just curious as to why your webui URL link to pixelserv stats goes via http rather than https ?
Got me worried when it kept saying it was "Not secure" - until I investigated the obvious ;).
I enjoy the reassurance of the padlock [tells me I have installed its ca.crt on client devices I'm testing from].
Your call as to whether you adapt or retain - Diversion still my absolute "go to" {ThumbsUp}
thelonelycoder
Part of the Furniture
There's a fine line between excellence and (swiss) perfection :cool:
Will be fixed in the next Diversion release, thanks for reporting.
Master3395
It is still happening in the latest version :/
Browser gives this error: NET::ERR_CERT_AUTHORITY_INVALID
Juli 10 2022
Diversion 4.3.1 is now available
thelonelycoder
Juli 10 2022
Did you import the pixelserv-tls certificate on the device/browser?
Master3395
Yes
Master3395
What browser are you using?
If Firefox, you have to import the certificate into it as well.
I use Edge, the latest version.
I tried Chrome also, same problem there, I also restarted both browsers after installing it.
thelonelycoder
Master3395
thelonelycoder
It says it's installed, but it's not installed in the root at all, and yes I have deleted the "personal" installation I did at first.
What can I do then?
Well, do as the link I linked says.
