Diversion Diversion with Wireguard Manager
Groot
On my RT-AX88U I've set up Wireguard Manager and all devices connected to it are running through VPN. I wanted to also install Diversion to block ads on all devices. However, I couldn't make it work. All devices were running on VPN but the ads were still visible.
Is it possible to make it work with Wireguard Manager?
There is a section specifically about Diversion further down:
Changing peer dns will for sure make Diversion work but it will also make you use wan dns instead of vpn dns which might not be what you want. Depending on how your system is setup there are acouple of options there.
//Zeb
