Hi. I'm currently using an AdGuard LAN instance as my DNS resolver on a GT-AX11000 Pro with asuswrt 388.2 (also had this with 388.1). In order to avoid bypasses and to force all queries to my server I'm trying out the DNS director but I'm noticing a behavior which breaks it. Whenever there is a change on the Adguard server install like an upgrade, the director hangs and queries fail until I turn off the feature (took me some time and many tries to isolate this to the director rather than the custom DNS server itself)
I've used both DoT and DoH upstreams on AdGuard which don't seem to be the issue after all, so I was wondering if this is a known issue or if there is more info I can contribute. Note that I do not have a full repro altough I known that AdGuard updates break queries until I turn off and then back on the director
Thanks in advance
Thanks in advance
