DNS Filter issues with iOS devices when iCloud private relay is on
Mr.Navigator
Hello all,
I'm experiencing issues specifically on iOS devices with private relay on, as it is bypassing DNS Filter entirely, meaning it's not blocking adult websites. I've tried different filters, even manually assigning the MAC address of a device to use the router settings, but no matter what I do, it's just not behaving as expected. Even manually setting the DNS IPv4 and IPv6 on the device, won't block adult websites. Issue is non-reproducible in windows devices and when private relay is disabled. Has anyone encounter a similar issue or dealing with a similar situation? What is your suggestion or resolution?
They use either DNS-over-TLS or DNS-over-HTTPS, which cannot be redirected by DNS Director because it uses a secure TLS connection to ensure that the DNS request isn't hijacked - which is what DNS Director in effect, hijacking DNS queries.
So you have to chose: Private Relay, or DNS Director. Can't use both.
Hello all,
So far as I know, Apple Private Relay makes its own DNS arrangements independent of the router.
The only way to enforce your own DNS with Private Relay is to include it in a DNS profile, installed on each client.
Profile/s can be found here, maybe elsewhere as well?
  • Like
Reactions: fsb
I tried adding to dnsmasq.conf.add
#block private relay
address=/mask.icloud.com/
address=/mask-h2.icloud.com/
which should (I think) show mask.icloud.com etc, as non existent hosts
which works from nslookup (on my machine)
500:[~]$ nslookup mask.icloud.com
Server: 2601:646:9e80:bb47::1
Address: 2601:646:9e80:bb47::1#53
** server can't find mask.icloud.com: NXDOMAIN
but when i turn on private relay it still works. I really want to block it completely. anyone figured out how?
Not possible IMHO.
Private relay bypasses dnsmasq totally, so whatever changes you make there will be irrelevant.
