1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
DNS Hierarchy? WAN DNS v DHCP Server v DNSFilter
Discussion in 'Asuswrt-Merlin' started by peepsnet, Feb 27, 2020.
  1. peepsnet
    peepsnet Regular Contributor
    Jul 16, 2019
    112
    Can someone explain the hierarchy in the 3 systems?
    Which one is the final authority in assigning the DNS servers to the clients?
  2. dave14305
    dave14305 Part of the Furniture
    May 19, 2018
    2,479
    USA
    1. DNSFilter overrides everything else for clients.
    2. LAN DHCP comes next, assuming it is populated with external DNS IPs.
    3. If no 1 or 2 is defined, then the router receives the client requests and forwards to the WAN DNS servers.
    Vexira, martinr, L&LD and 1 other person like this.
  3. peepsnet
    Jul 16, 2019
    112
    Thank you so much for the quick answer!! This is what I though but wanted to make sure
    What is the function "Global Filter Mode" under DNSFilter in this whole process???
  4. dave14305
    May 19, 2018
    2,479
    USA
    Global mode is what every device is subject to, unless they have a client-specific rule defined in the lower section to either a) set as No Filtering or b) choose a different filter than the Global default. For example, I might want Quad9 setup for the whole network (Global mode), but want Cleanbrowsing Family for my childrens’ devices. Or I might want my iPad exempt from filtering so I can go wherever I want.
    Vexira and L&LD like this.
  5. Chris_J
    Chris_J Regular Contributor
    Dec 10, 2019
    104
    UK
    Not wishing to hijack your thread, but I had a similar question and it saves making another thread.
    Since we now know that DNSFilter takes first priority, can one use this to point to a DNS server located inside the network (i.e. Unbound running on a RPi)?
    Vexira likes this.
  6. Vexira
    Vexira Part of the Furniture
    Jan 20, 2017
    2,033
    Australia
    Yes I use to for pihole, you have to point it to the server IP, in my case the pi's IP.
    I set it to custom one and global filter to custom one.
  7. Chris_J
    Dec 10, 2019
    104
    UK
    Perfect. This is what I expected so it makes me feel more sure of what I am doing.
    So basically:
    DNSFilter > Custom > Custom 1 > 192.168.1.XX
    Hopefully this works just as well with Unbound as it does with Pihole.
  8. martinr
    martinr Part of the Furniture
    Nov 27, 2014
    2,425
    Manchester, United Kingdom
    Sure, so long as you’re running Unbound on your Raspberry Pi.
    Chris_J likes this.
