DNS masq related question
Did your ctrld listener port change recently from port 5354 to 53? The dnsmasq.postconf suggests it was 5354, but the netstat and /etc/dnsmasq.conf show ctrld listening on port 53 and 5353 now, which could also explain the original dnsmasq startup failure.
To be honest, I have no idea - I was running some commands earlier to verify ctrld was working properly and i may have inputted 5354 but more a as verifying measure based on instructions rather than making any any changes. So the ports in these configs should more/less match? maybe i will download the configurations tomorrow again to compare them together. Or if there’s anything else I should do, please let me know. Thank you for all your help.!
I
Yes, thank you, now I see what you are saying, upon regenerating these, now my dnsmasq.conf also shows "server=127.0.0.1#5354" - just like my dnsmasq.postconf which also shows: pc_append "server=127.0.0.1#5354" "$config_file"
Whereas before the dnsmasq showed ""server=127.0.0.1#53"
cat /jffs/scripts/dnsmasq.postconf
# GENERATED BY ctrld - DO NOT MODIFY
#!/bin/sh
config_file="$1"
. /usr/sbin/helper.sh
pid=$(cat /tmp/ctrld.pid 2>/dev/null)
if [ -n "$pid" ] && [ -f "/proc/${pid}/cmdline" ]; then
pc_delete "servers-file" "$config_file" # no WAN DNS settings
pc_append "no-resolv" "$config_file" # do not read /etc/resolv.conf
# use ctrld as upstream
pc_delete "server=" "$config_file"
pc_delete "add-mac" "$config_file"
pc_delete "add-subnet" "$config_file"
pc_append "add-mac" "$config_file" # add client mac
pc_append "add-subnet=32,128" "$config_file" # add client ip
pc_delete "dnssec" "$config_file" # disable DNSSEC
pc_delete "trust-anchor=" "$config_file" # disable DNSSEC
pc_delete "cache-size=" "$config_file"
pc_append "cache-size=0" "$config_file" # disable cache
# For John fork
pc_delete "resolv-file" "$config_file" # no WAN DNS settings
# Change /etc/resolv.conf, which may be changed by WAN DNS setup
pc_delete "nameserver" /etc/resolv.conf
pc_append "nameserver 127.0.0.1" /etc/resolv.conf
exit 0
fi
# GENERATED BY ctrld - EOF
cat /jffs/configs/dnsmasq.conf
pid-file=/var/run/dnsmasq.pid
user=nobody
bind-dynamic
interface=br0
interface=pptp*
no-dhcp-interface=pptp*
no-resolv
no-poll
no-negcache
min-port=4096
dns-forward-max=1500
bogus-priv
domain-needed
dhcp-range=lan,192.168.50.2,192.168.50.254,255.255.255.0,86400s
dhcp-option=lan,3,192.168.50.1
dhcp-option=lan,252,"\n"
dhcp-authoritative
no-dhcp-interface=tun22
no-dhcp-interface=tun23
dhcp-name-match=set:wpad-ignore,wpad
dhcp-ignore-names=tag:wpad-ignore
dhcp-script=/sbin/dhcpc_lease
script-arp
edns-packet-max=1232
ipset=/blocklist.greensnow.co/darklist.de/feodotracker.abuse.ch/iplists.firehol.org/lists.blocklist.de/myip.ms/raw.githubusercontent.com/rules.emergingthreats.net/sigs.interserver.net/blocklist.de/talosintelligence.com/voipbl.org/ipdeny.com/ipapi.co/api.db-ip.com/api.bgpview.io/asn.ipinfo.app/speedguide.net/otx.alienvault.com/github.com/Skynet-WhitelistDomains # Skynet
ipset=/astrill.com/strongpath.net/snbforums.com/bin.entware.net/nwsrv-ns1.asus.com/pool.ntp.org/asuswrt-merlin.net/asuswrt.lostrealm.ca/big.oisd.nl/codeload.github.com/diversion.ch/drv.ms/entware.diversion.ch/entware.net/fwupdate.asuswrt-merlin.net/garycnew.github.io/localhost.localdomain/maurerr.github.io/mirrors.bfsu.edu.cn/mirrors.cernet.edu.cn/Skynet-WhitelistDomains # Skynet
ipset=/mirrors.cqupt.edu.cn/mirrors.nju.edu.cn/oisd.nl/onedrive.live.com/openstreetmap.org/pgl.yoyo.org/pkg.entware.net/small.oisd.nl/someonewhocares.org/sourceforge.net/sunrisesunset.io/urlhaus.abuse.ch/Skynet-WhitelistDomains # Skynet
no-resolv
add-mac
add-subnet=32,128
cache-size=0
homenet@RT-AX88U_Pro-F4A0:/tmp/home/root#
homenet@RT-AX88U_Pro-F4A0:/tmp/home/root# d
