Dns
kublai
Is there somewhere in the router that tells you currently what DNS/Gateway your router is getting from the ISP? I have my PC setup with a static IP so I have to use a manual DNS entry and I want it to match what my Router is using.
Thanks.
Via command line (telnet) you can enter
cat /etc/resolv.conf
wich will give you the current DNS servers / ip addresses for the primary and secoundary one.
With kind regards
Joe :cool:
When I telnet to the router and did that command I got nameserver 127.0.0.1
With kind regards
Joe :cool:
Internet Status
Just click on the "Internet Status" icon. The current DNS servers will be listed below the WAN IP.
