Dnscrypt from opendns
shooter40sw
Hi guys i would like to install dnscrypt i use 354.29 Merlin on N66u great Job! ... I know tomato with a checkmark can be done as i saw in Google... Is there a way to do it without much hassle? A guide? Thanks for the help
After rebooting router I don't have access to internet, in router's ui pppoe connection is on
Wasn't started, I do it manually but won't stay started and no internet connection to pc.
Oh, my! Looks like I misunderstood Frank Denis in Issue#3. Please, update dnscrypt-proxy:
/opt/etc/init.d/S09dnscrypt-proxy stop
opkg update
opkg upgrade
And start it again:
/opt/etc/init.d/S09dnscrypt-proxy start
Same thing, did you tried on your router and works?
Yes! You should see those strings when dnscrypt-proxy started:
cat /tmp/syslog.log
Jun 26 16:52:16 admin: Started dnscrypt-proxy from .
Jun 26 18:47:14 dnscrypt-proxy[20159]: Initializing libsodium for optimal performance
Jun 26 18:47:14 dnscrypt-proxy[20159]: Generating a new key pair
Jun 26 18:47:14 dnscrypt-proxy[20159]: Done
Jun 26 18:47:14 admin: Started dnscrypt-proxy from .
Jun 26 18:47:14 dnscrypt-proxy[20159]: Server certificate #1369080797 received
Jun 26 18:47:14 dnscrypt-proxy[20159]: This certificate looks valid
Jun 26 18:47:14 dnscrypt-proxy[20159]: Server key fingerprint is 915C:9A0C:5F0F:5EB4:784E:E450:FE8B:C115:B1DE:5538:7718:25D5:C305:CCB7:9532:0309
Jun 26 18:47:14 dnscrypt-proxy[20159]: Proxying from 127.0.0.1:65053 to 208.67.220.220:443
and those one when dnsmasq is started:
cat /tmp/syslog.log
Jun 26 18:48:27 dnsmasq[20280]: started, version 2.65 cachesize 1500
Jun 26 18:48:27 dnsmasq[20280]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack
Jun 26 18:48:27 dnsmasq[20280]: warning: ignoring resolv-file flag because no-resolv is set
Jun 26 18:48:27 dnsmasq[20280]: asynchronous logging enabled, queue limit is 5 messages
Just for sure, here is my dnsmasq custom config:
# cat /jffs/configs/dnsmasq.conf.add
### Dnscrypt
no-resolv
server=127.0.0.1#65053
I think I'm bit lucky here because there was other guys, caught by following deadlock:
  • dnscrypt-proxy can't accept received certificate because of wrong system date/time,
  • ntp client can't receive right time because DNS resolver (dnscrypt-proxy) is not working.
To avoid this deadlock, add following content to /jffs/scripts/post-mount
#!/bin/sh
for ip in $(/opt/sbin/dnscrypt-proxy-hostip $(nvram get ntp_server0))
do
echo $ip $(nvram get ntp_server0) >>  /etc/hosts
done
and make it executable:
chmod +x /jffs/scripts/post-mount
Hm-m-m, strange. After running:
do
done
there must be following strings:
83.169.43.165 pool.ntp.org
178.63.14.131 pool.ntp.org
131.234.137.23 pool.ntp.org
129.70.132.37 pool.ntp.org
Yes, something wrong with the script
admin@RT-AC66U:/tmp/home/root# sh /jffs/scripts/post-mount
[: /tmp/mnt/sda1: unknown operand
/jffs/scripts/post-mount: line 11: /opt/sbin/dnscrypt-proxy-hostip: not found
In /opt/sbin/ is only dnscrypt-proxy so I changed the script from
to
for ip in $(/opt/sbin/dnscrypt-proxy $(nvram get ntp_server0))
and after reboot
[INFO] Initializing libsodium for optimal performance
[INFO] Generating a new key pair
[INFO] Done
[ERROR] Unable to bind (UDP) [Address already in use]
I'm done for today, my hdd will blow up
admin@RT-AC66U:/tmp/home/root# tune2fs -l /dev/sda1 | grep 'Mount count'
Mount count: 61
With wan-start script it's working but it takes 4-5 minutes to start :(
http://pastebin.com/zJV0jriG
Fine! Take a look at your log: dnscrypt started successful just when right system time was received. The last thing we may tweak is to restart ntp client immediately to eliminate this 4-5 min. delay.
Still not working, should I put the script in wan-start maybe?
We may, but careful. There may be a race condition: we can't say what will happen earlier: WAN start or USB mount.
Give me a few minutes to write final solution.
Ok, starting over.
  1. Install Entware,
  2. Install dnscrypt:
    opkg install dnscrypt-proxy dnscrypt-proxy-hostip
  3. Tell router to use it:
    echo "no-resolv" > /jffs/configs/dnsmasq.conf.add
    echo "server=127.0.0.1#65053" >> /jffs/configs/dnsmasq.conf.add
  4. Put this content to /jffs/scripts/wan-start:
    #!/bin/sh
    # Wait up to 15 seconds to make sure /opt partition is mounted
    i=0
    while [ $i -le 15 ]
    do
        if [ -d /opt/tmp ]
        then
            break
        fi
        sleep 1
        i=`expr $i + 1`
    done
    # Now resolve DNS name for NTP server
    ntp_name=$(nvram get ntp_server0)
    grep "$ntp_name" /etc/hosts > /dev/null 2>&1 || \
    for ip in $(/opt/sbin/dnscrypt-proxy-hostip $ntp_name)
    do
        echo $ip $ntp_name >>  /etc/hosts
    done
    # and restart NTP client to eliminate 4-5 mins delay
    killall ntp && sleep 1
    service restart_ntpc
    chmod +x /jffs/scripts/wan-start
  5. Reboot router and make sure it works.
Here is boot log, look OK: dnscrypt-proxy started after 25 seconds of booting. Waiting for confirmation before changing first post.
