Unbound dnsmasq config/entries
BeachGuy
I tested unbound with chatGPT and it found an error. Wanted to check with you and see if this is corrrect. If so can amtm/unbound automatically add these lines upon install/refresh?
Your current /jffs/configs/dnsmasq.conf.add only contains Skynet whitelist IP sets, which is fine — but it's missing the required lines to tell dnsmasq to forward DNS requests to Unbound (running at 127.0.0.1#53).
✅ Fix: Add These Two Lines
Edit /jffs/configs/dnsmasq.conf.add and add the following at the top:
no-resolv
server=127.0.0.1#53
Explanation:
Directive
Purpose
no-resolv
Tells dnsmasq not to use /etc/resolv.conf (which might list ISP DNS)
server=127.0.0.1#53
Forwards all DNS to Unbound running on localhost
vi /jffs/configs/dnsmasq.conf.add
Add these lines at the top:
no-resolv
server=127.0.0.1#53
Was Unbound not working?
It was working but hard to tell if it was resolving to ISP. It seems to be slightly slower now (barely noticeable) which may be due to the fact that now it is resolving to authoritative servers?
Yes thanks. It resolved to my public IP before and after I changed it so apparently no difference.
Other test that you can do is, into router (SSH), use `nslookup some_domain` and check if router is using unbound by itself, or it is using resolv.conf.
That resolves to ISP DNS because I was told to set WAN DNS to something so that when router boots it can set time (ntp server) etc. before unbound loads.
At WAN tab, you could try to use 127.0.0.1 as primary DNS, and your ISP DNS as secondary DNS. If primary fails (Unbound is not loaded yet), it will fallback to secondary DNS server.
Good idea, thanks.
Hey btw, I see you're running a similar setup (2x GT-AX6000 ethernet backhaul). What is Packard V-1650?
