Do I use udp or tcp opvn files - can download either from nordvpn
vw-kombi
Setting up client vpn.
Im offered tcp or udp ovpn files from nord.
Was not given a choice for PIA.
Which do I choose ?
Thanks.
Either, your choice. I feel that in some cases UDP may be faster while TCP should reduce errors.
Sent from my SM-T380 using Tapatalk
UDP is better if you use something like VoIP over the tunnel (which I highly doubt), but TCP tends to be more stable (and even a bit faster for some users).
Best is to test both to see which works best for your specific needs.
For mobile devices using OpenVPN, especially phones, go with TCP. For your router or desktops and laptops on home wifi try UDP. If the connection is unstable then try TCP.
