pixelserv Does "How to best run Pixelserv tls on asuswrt" still apply?
blacksheep
I'm running the latest Diversion v4 Standard and pixelserv. It's blocking ads on my RT-AX86U.
I noticed a link at the bottom of this pixelserv page - note last updated several years ago):
https://www.snbforums.com/threads/pixelserv-a-better-one-pixel-webserver-for-adblock.26114/
In that page, there was a link to "How to best run Pixelserv tls on Asus wrt Merlin" so I clicked it.
https://github.com/kvic-z/pixelserv-tls/wiki/How-to-best-run-pixelserv-tls-on-Asuswrt-Merlin
They suggest creating a virtual interface via the router's cli by adding a wan-start file in /jffs/scripts/
ifconfig br0:pixelserv 192.168.1.3 up
logger -t $(basename $0) "br0:pixelserv 192.168.1.3 created."
I've been reading this forum for answers and noticed wan-start is deprecated and replaced by wan-event.
They also mention pixelserv needs to be set to listen to its own ip address in /opt/etc/init.d/580pixelserv-tls.
The site also recommends adding PRECMD="ulimit -s 64"in /opt/etc/init.d/580pixelserv-tls to increase performance and run on tighter memory resources.
My questions are:
Do I need to bother with setting up Pixelserv TLS? I'm just using this on my router to block ads; nothing too fancy.
Do I still need to create a virtual interface for pixelserv?
(If so, do I simply create a wan-event file in /jffs/scripts/ whereas it would have been named wan-start in the past? There is currently no wan-* in my scrips folder)
Do I need to direct pixelserv to its own IP address or is this done in the install script now?
(I think I see $psIP variable that may handle this in /opt/etc/init.d/580pixelserv-tls)
Do I need to add "ulimit -s 64" to the PRECMD in /opt/etc/init.d/580pixelserv-tls?
thelonelycoder
Part of the Furniture
Diversion does all that for you automatically.
elorimer
All those old good times. I did see a sign of life from @kvic in July in another place.
