wordlesswind
Hello guys,
I encountered a problem when using DoT: I cannot use a DoT, but the others are working fine.
I know I should go to Xwrt-Vortex for help, but I think this should not be a problem with third-party content.
And I can use Google and Cloudflare's DoT services normally, but this one does not work.
This DoT does not have a domain, it only uses IP addresses and IP certificates.
Its DoH: https://101.6.6.6:8443/dns-query
Thank you!
I have no problems when using kdig to test, but I cannot use it in R7000 (Firmware 384.19 by Xwrt-Vortex, CEF 1.3.0.7).IP: 101.6.6.6
Port: 8853
Host: 101.6.6.6
I don't know how to test in Router, can someone help me?kdig -p 8853 +dnssec +tls-ca +tls-host=101.6.6.6 www.cloudflare.com @101.6.6.6
;; TLS session (TLS1.2)-(ECDHE-SECP256R1)-(RSA-SHA256)-(AES-256-GCM)
;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 442
;; Flags: qr rd ra ad; QUERY: 1; ANSWER: 3; AUTHORITY: 0; ADDITIONAL: 1
;; EDNS PSEUDOSECTION:
;; Version: 0; flags: do; UDP size: 4096 B; ext-rcode: NOERROR
;; QUESTION SECTION:
;; www.cloudflare.com. IN A
;; ANSWER SECTION:
www.cloudflare.com. 300 IN A 104.16.123.96
www.cloudflare.com. 300 IN A 104.16.124.96
www.cloudflare.com. 300 IN RRSIG A 13 3 300 20201130074129 20201128054129 34505 www.cloudflare.com. sVwSyLLAL0J4Gk0jLn4gGzV4M/fVhwM1wXV30ZKjzj6nCZFaheqznbbguFI4epLJLOCWOWGs1CX03n8wvQ94Dw==
;; Received 193 B
;; Time 2020-11-29 14:41:29 CST
;; From [email protected](TCP) in 286.1 ms
Thank you!
