Double NAT - DHCP Option 61 without merlin?
thewizard1241
So i recently bought an AX86u and ran a double NAT, but long story short, running double NAT gives latency spikes and issues over wireless. I tested this using a dslac68u connected to the AX86u. To confirm it wasnt the AX86u, i connected my ISP's modem to the DSLAC68u, and the same results consistently.
The issue is, my ISP Requires DHCP Option 61 on the router, which i know merlin firmware supports. However as ofc we dont know if the AX86u will merlin firmware at all, i was wondering if there was any way possible to just enable DHCP Client option 61 within the AX86u. Like any command i could use by SSHing or something?
My plan is to use a draytek vigor modem in bridge mode, then use option 61 on the AX86u
Cheers
