flyboytyler
This week I purchased an RT-N66R router, running firmware 3.0.0.4.1763
One of the features I purchased it for the was the bit torrent client. I have found an issue though, whenever I enable the download master, the router consumes my outgoing bandwidth, not sure what it is sending, or where it is sending it, it is a bit of a concern though. I have tried the following:
1. I set my torrent settings to 5kb up.
2. For amule I set the ip address to 127.0.0.1, as I read somewhere that might be the issue.
Neither of these steps have resolved the problem, I have powered off the router numerous times to see if it is something that only changes after a reboot, no difference.
Right now, if I want to use the torrent feature, I have to enable and disable the download master, otherwise I have no bandwidth left outgoing to do anything else.
Oh also, to be clear, I have emptied the torrent folders to make sure it isn't just a case of the 5kb upload not being honored.
After reading other posts in other forums, I discovered that the RT-N66R is just an RT-N66U, so I decided to install the Merlin firmware (love the extra features thank you). I installed 220.18 yet experience the same issue
Would love to be able to use this feature without losing my outgoing speed.
Anyone have any ideas?
Many thanks
Carl
Many thanks
Carl
