shooter40sw
Hi guys after upgrade to 372-2, (did not heavy download nothing on the 354 FW but on the 270 I did with no issues, all Merlin Builds) The HDD USB keeps turning off, the light indicator goes down on the router does not detect no longer the HDD, in the system logs I just see the router reset itself, it starts all services the ntp watch goes to December 31 , this happens randomly, but usually very early after the download begins, before this happens in the logs I see this ul 19 06:30:09 kernel: usb 1-1.1: reset high speed USB device using ehci_hcd and address 8, then the name of the download,its an external 160GB HDD, please any other work around that does not involve installing entware?, And if there is no other way around in the time, does entware need to be installed on a ext3 partition and always connected? what happens to the router if this is not connected, I dont want to damage the router (N66U).. And I want to keep things simple, thanks.
