Trying to figure out WTH is causing drops in the router's system log for an ASUS RT-AC66U with Motorola SB6141 cable modem. Drops seem to happen in the wired connection between the router and the cable modem since the cable modem MAC address is referenced over and over, but just spit balling.
IPv6 is not currently enabled on router, and curiously on the cable modem's config page it shows "Modem's IP Mode: IPv6 Only". Possible hint? I would prefer to stay away from the complexity of IPv6 until I am paying a price for not using... like speed or instability issues.
Any help greatly appreciated.
CABLE MODEM CONFIG PAGE:
GENERAL SYSTEM LOG FROM ASUS ROUTER (some info redacted):
Dec 30 15:51:13 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=96.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=676 TOS=0x00 PREC=0x00 TTL=52 ID=52235 PROTO=UDP <1>SPT=5060 DPT=32497 LEN=656
Dec 30 15:51:13 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=96.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=676 TOS=0x00 PREC=0x00 TTL=52 ID=52236 PROTO=UDP <1>SPT=5060 DPT=32497 LEN=656
Dec 30 15:51:14 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=96.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=676 TOS=0x00 PREC=0x00 TTL=52 ID=52237 PROTO=UDP <1>SPT=5060 DPT=32497 LEN=656
Dec 30 15:51:16 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=96.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=676 TOS=0x00 PREC=0x00 TTL=52 ID=52238 PROTO=UDP <1>SPT=5060 DPT=32497 LEN=656
Dec 30 15:51:19 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=96.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=676 TOS=0x00 PREC=0x00 TTL=52 ID=52239 PROTO=UDP <1>SPT=5060 DPT=32497 LEN=656
Dec 30 15:51:40 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=183.XXX.XX.XXX DST=XX.XX.XXX.XX <1>LEN=40 TOS=0x00 PREC=0x00 TTL=51 ID=39968 PROTO=TCP <1>SPT=3187 DPT=23 SEQ=1286607188 ACK=0 WINDOW=8539 RES=0x00 SYN URGP=0
Dec 30 15:52:04 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=180.172.188.153 DST=XX.XX.XXX.XX <1>LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=1378 PROTO=TCP <1>SPT=6750 DPT=22 SEQ=1286607188 ACK=0 WINDOW=17852 RES=0x00 SYN URGP=0
Dec 30 15:52:15 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=88.XXX.XX.XXX DST=XX.XX.XXX.XX <1>LEN=44 TOS=0x00 PREC=0x00 TTL=228 ID=39508 PROTO=TCP <1>SPT=41998 DPT=23 SEQ=1368850432 ACK=0 WINDOW=14600 RES=0x00 SYN URGP=0 OPT (020405AC)
Dec 30 15:52:39 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=123.165.233.159 DST=XX.XX.XXX.XX <1>LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=47701 PROTO=TCP <1>SPT=44481 DPT=22 SEQ=1286607188 ACK=0 WINDOW=64498 RES=0x00 SYN URGP=0
Dec 30 15:53:13 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=183.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=48 TOS=0x00 PREC=0x00 TTL=113 ID=15550 DF PROTO=TCP <1>SPT=20644 DPT=1433 SEQ=542248024 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405A001010402)
Dec 30 15:53:15 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=183.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=48 TOS=0x00 PREC=0x00 TTL=113 ID=18628 DF PROTO=TCP <1>SPT=20644 DPT=1433 SEQ=542248024 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405A001010402)
Dec 30 15:53:34 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=187.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=40 TOS=0x00 PREC=0x00 TTL=236 ID=36798 PROTO=TCP <1>SPT=2772 DPT=6789 SEQ=1286607188 ACK=0 WINDOW=5840 RES=0x00 SYN URGP=0
Dec 30 15:55:58 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=96.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=676 TOS=0x00 PREC=0x00 TTL=52 ID=52265 PROTO=UDP <1>SPT=5060 DPT=32497 LEN=656
Dec 30 15:55:58 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=96.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=676 TOS=0x00 PREC=0x00 TTL=52 ID=52266 PROTO=UDP <1>SPT=5060 DPT=32497 LEN=656
Dec 30 15:55:58 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=96.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=676 TOS=0x00 PREC=0x00 TTL=52 ID=52267 PROTO=UDP <1>SPT=5060 DPT=32497 LEN=656
Dec 30 15:55:59 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=96.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=676 TOS=0x00 PREC=0x00 TTL=52 ID=52268 PROTO=UDP <1>SPT=5060 DPT=32497 LEN=656
Dec 30 15:55:59 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=96.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=676 TOS=0x00 PREC=0x00 TTL=52 ID=52269 PROTO=UDP <1>SPT=5060 DPT=32497 LEN=656
Dec 30 15:56:01 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=96.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=676 TOS=0x00 PREC=0x00 TTL=52 ID=52270 PROTO=UDP <1>SPT=5060 DPT=32497 LEN=656
Dec 30 15:56:04 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=96.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=676 TOS=0x00 PREC=0x00 TTL=52 ID=52271 PROTO=UDP <1>SPT=5060 DPT=32497 LEN=656
Dec 30 15:56:43 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=158.xxx.xx.xxx DST=XX.XX.XXX.XX <1>LEN=441 TOS=0x18 PREC=0x00 TTL=45 ID=38703 DF PROTO=UDP <1>SPT=5107 DPT=5060 LEN=421
Dec 30 15:56:52 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=124.xxx.x.xxx DST=XX.XX.XXX.XX <1>LEN=52 TOS=0x00 PREC=0x00 TTL=44 ID=8898 DF PROTO=TCP <1>SPT=64169 DPT=1433 SEQ=3251678201 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030001010402)
Dec 30 15:56:53 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=23.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=40 TOS=0x00 PREC=0x00 TTL=239 ID=54321 PROTO=TCP <1>SPT=33725 DPT=80 SEQ=2877263258 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0
Dec 30 15:56:55 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=124.XX.XX.XX DST=XX.XX.XXX.XX <1>LEN=52 TOS=0x00 PREC=0x00 TTL=44 ID=19439 DF PROTO=TCP <1>SPT=64169 DPT=1433 SEQ=3251678201 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030001010402)
Dec 30 15:57:01 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=95.XX.XX.XX DST=XX.XX.XXX.XX <1>LEN=44 TOS=0x00 PREC=0x00 TTL=233 ID=57780 PROTO=TCP <1>SPT=10889 DPT=23 SEQ=1179975680 ACK=0 WINDOW=14600 RES=0x00 SYN URGP=0 OPT (020405AC)
Dec 30 15:57:10 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=109.XX.XXX.XX DST=XX.XX.XXX.XX <1>LEN=40 TOS=0x00 PREC=0x00 TTL=235 ID=47018 PROTO=TCP <1>SPT=61923 DPT=6789 SEQ=1286607188 ACK=0 WINDOW=5840 RES=0x00 SYN URGP=0
Dec 30 15:57:22 kernel: DROP <4>DROP IN=eth0 OUT= MAC=[cable modem MAC address]<1>SRC=125.XX.XX.XX DST=XX.XX.XXX.XX <1>LEN=44 TOS=0x00 PREC=0x00 TTL=236 ID=28288 PROTO=TCP <1>SPT=46652 DPT=6789 SEQ=1286607188 ACK=0 WINDOW=5840 RES=0x00 SYN URGP=0 OPT (020405AC)
