ds415+ bonding , which selection
pete y testing
hi guys
just got the rt-ac88u and enabled bonding on its port 1 /2 , what im wondering is out of the selection in the 415+ for bonding which do i choose , i assume dynamic link aggregation to ensure max throughput or is it something other
just notice something strange when monitoring the throughput on the 88u , when i transfer via wifi it only uses lan 2 , but when i use ethernet it reads through lan 1 and writes through lan 2 , this is also the same if i setup the same scenario on the ac5300 ?
any one able to suggest whats going on as its a bit confusing
pete
