DSL-AC68u Firmware upgrade problem
Abhineet Mahajan
I need help.
My current version for DSL-AC68u router is 3.0.0.4.386_38287-gb31556f
When Iam trying to upgrade from asus app, firmware version is showing 3.0.0.4.386_39648 ,and when Iam trying to upgrade its showing completed, but when I am checking the firmware version its showing (even after reboot)
3.0.0.4.386_38287-gb31556f, and again asking for upgrade.
How should I fix it
Unplug any USB devices reboot and try again. Don't use the Asus router app to install update. Instead download the new firmware from there support site unzip it and install manually from the routers User interface.
Thankyou , to understand more about manual update
Please see the attachment ( the rounded one with red color is the current firmware) so do I need to do all 1,2,3 and 4 the marking I did in the attachement !! or directly uplading the 4 th one will work.
Also I noticed (1 and 2 ) / (3 and 4 ) markings in screenshots has same Firmware number.
Download and install the latest version skip over the rest. The latest version contains all the fixes and updates from previous versions so the latest is what you want.
I second that - the latest build fixes a lot of bugs
