DSL-AC68U running Gigafast?
BellamyB
Hello all from a noob here!
I’m currently running an ASUS DSL-AC68U on my terrible bt broadband connection (20/2) with just the standard 386 software (not merlin). However, I have just switched to Vodafone Gigafast 900mbps package, cityfibre install, which I’ll be getting in just over a week.
Just wondering if my current router will be able to handle the speeds when I switch over?
And any recommendations on what kind of settings I should be running?
Much appreciated!
Much appreciated!
I'm not sure if that new ISP is xDSL or not, but my install notes may help with baseline AC68u/AC86U router configuration.
Then use a wired PC to find out if your AC68U can deliver the nominal dn/up ISP speeds you are provisioned for.
OE
